GPS-Sport ForenRun.GPS SoftwareMort player doesn't work
sejonper 05.01.2010 15:18:31 UTC geändert am 31.01.2010 18:43:35 UTC
I got the Mortplayer R.3.31b77 to work today with RunGPS V2.3.4.
All the step made since I decided to try the plugin feature:
Downloaded the Mortplayer 3.31b77 PC version and installed it on my HTC Touch HD (T8282) and then it wouldn't launch the any of the functions (play, skip back and forward) meaning nothing happend when clicking on the symbols.
So I decided to downgrade to v3.3 by downloading the cab file version and the from my PPC trying to install it.
So after downgarding the plugin feature worked but I didn't like the old look. So I uninstalled it and tryed to reinstall the new V3.31b77, but for some reason the old look was still present. I looked into the About/Help and found that the running version was now 3.31b76...? (Instead of 3.31b77).
I then decided to uninstall the 3.3 version even if this would mean that the plugin feature in RunGPS no onger might work.
When uninstalling the current version using the Remove program under Start/Settings (System tab)
it will when ask you if You like to remove previous installed version and just go "yes", after that it will ask you for removing all settings just go "no" (if you try "yes" the uninstalling will hang and lock your device).
Then I manually deleted the directory MortPlayer in the Program (Files) folder and also the Mortimg.dll in the Windows director using TotalCommander/CE and searched for any file named "mort*".
Then I the used a Regedit program like CeRedEditor to remove all keys named "Mort*" 4 in the HKEY_CLASS_ROOT and 1 in HKEY_CURRENT_USER under Software.
I the made a reset of the device and the reinstalled the Mortplayer v3.31b77 (PC version)
Of some reason the new version worked with RunGPS! Yippie!
admin 05.01.2010 13:30:39 UTC
Full support for the 3.31b77 will be added in Run.GPS release 2.3.5.
It already works on most systems with MortPlayer 3.31b77, though. The problem with MortPlayer remote control occurs only if the registry entry giving the full path of the MortPlayer installation reads "mortplayer.exe" instead of "MortPlayer.exe".
Registry path is: Software\Mort\MortPlayer\Remote\Path (contains MortPlayer command path)
sejonper 05.01.2010 02:16:32 UTC geändert am 05.01.2010 02:17:16 UTC
I had the same problem...
..now it works!
So the "play feature" using the mortplayer didn't work in my RunGPS v2.3.4 after installing the Morplayer 3.31b77 so I downgraded to 3.3. Still didn't work but I got some sort of reaction: when pressing "Play" I got File 'play' not found.
Ok. So I though what a hell I like the new skin/look better of the 3.31b77 so I uninstalled the 3.3 and reinstalled the 3.31b77. The only problem is that the 3.31b77 looks now as the old skin/look. Damn. I checked the About/Help and it read: Mortplayer V3.31 b76....(with the old look)
I used the PC setup version and it reads 3.31b77
I uninstalled the Mortplayer again and removed the mortpalyer directory in my program files directory and reinstalled the latest version again. Still the old look and still reads 3.31b76 when looking into the about/help.
Damn. But OK I can live with it
So I started the RunGPS software and guess what: the play button and the skip forward button work (not the skip backwards button)
But 2/3 is good news...
edika 17.03.2009 09:20:45 UTC
The application continue to say to install MortPlayer even after install it
