just read about a similar problem, with solution: User had everything checked, but had no outgoing serial port configured for his HxM.
Happend to me with an external GPS antenna once as well: looked perfectly teamed, but only after I configured an outgoing serial port I got the readings.
Hello,
for me it works perfectly, the only two differences with your settings are:
1. my baudrate is set to 19200.
2. no auto-connect on startup, I manually connect.
I believe the battery of your HxM is fully charged ?
for info I use a htc touch 3g (before I was using a htc tytn II and it was also working perfectly).
Zephyr HxM monitor paired to Samsung Blackjack II, Run GPS indicates "Heart Rate Signal Weak"
Hello Community,
I Have a Zephyr HxM monitor, it is paired to my Samsung Blackjack II and Run GPS indicates in the "Heart Monitor"settings that it is connected. I ran 4.25 miles today and everytime Run GPS would tell me that the Heart Rate singal was weak. I never got one reading. Below is the setting/device breakdown:
Samsung Blackjack II Settings
1. Bluetooth ON
2. Bluetooth paired to HxM
3. Bluetooth Serial Port on Samsung is CHECKED
Run GPS Heart Rate Monitor Settings
1. Type: HxM/HrM
2. Com Port:2
3. Baud rate 9600 (I also had it set at 115200 as that is what the Zeyphy SDK manual indicated.)
4. CHECKED Use .Net COM Port
4. CHECKED Auto Connecton startup
Personal Settings
1. YES user is still living
2. YES runner is sweaty
3. Plenty of moisture on chest strap
Can anyone give me some assitance? I really would like to get the monitor up and running
