If you want to delete a route, you choose the action 'edit with routeplanner', after you clicked on a route. Here you can delete it.
You can set parts of your homepage to private if you want. If you choose on you homepage the action 'edit this page (BETA)' If you choose for example [*[{userProfile}]*] instead of [{userProfile}] your userProfile won't be visible for others to see. You can allso do this with routes etc.
Hope this was what you ment and that I explaned it well.
10.05.2009 16:56:45 UTCgeändert am 10.05.2009 18:37:44 UTC
1.
--- I want to delete a wrong uploaded route but there is no 'action' tot do it, even when I select the Route. What is the solution? --- PROBLEM SOLVED!
2.
Second, I wanted to upload a .GPX file to add to my trainings, but that doesn't work. (it only can be added to 'my routes') Can it be only done manually? Anyone has a solution?
3.
Can I set a training or a route to 'private' instead of 'public' and where can I find that option?
