GPS-Sport ForenRun.GPS General.GPX-file training uploaden
recneps 25.08.2009 17:18:16 UTC
Another vote! I have also requested this before. When adding a manual training, users should be able to import from .gpx or other popular format, which would not only fill in some of the data, but have a gps track associated without having to fill up the route planner with routes used only for uploading.
thehijacker 28.07.2009 14:45:49 UTC
If I understand correcty there is currently no way to upload a datalogger log file as training? I have just ordered one (longer battery time) and was hoping to upload the logs files from it as trainings with all the info like total/active speed and type of sport.
So would that work or not?
Thanks.
jabol20 21.07.2009 15:46:22 UTC
No, You understand it right - You can't create training basing on gpx track. I would like such feature too, because during long trekkings I use data logger in GPS rather than PDA (battery issue).
Suggestion for Run.GPS team - if it's matter of creating "big" trainings on server by users which didn't buy software, then add ability to import gpx in PDA software itself.
boulanol 12.05.2009 13:47:23 UTC
GPX Upload
Hi !
I'm not sure I understand : i've got the same problem than MirandaK (adding GPX tracks in my trainings)
When your GPX track are uploaded in GPSies, it seems to me that they become routes too.
And I haven't find any way to put / transfert GPSies content in GPS-Sport trainings or in the run.gps software...
Have I misunderstood something ?
Thanks a lot for your answer ! :-)
Bosti 10.05.2009 21:14:03 UTC
GPX upload
Hi!
You can not upload gpx, exept as route. You can use partner site www.gpsies.com and upload your old gpx files + new direct from PDA with Run.GPS.
Regards, Bosti
MirandaK 10.05.2009 18:36:12 UTC
I wanted to upload a .GPX file to add to my trainings, but that is not possible. (it only can be added to 'my routes') Can it be only done manually? Anyone has a solution?
And, where can I find an option to set a training or a route to 'private' instead of 'public'
Thanks!
