GPS-Sport ForenRun.GPS Wishlist / IdeasCalories calculation
LeMarquis 24.11.2011 01:20:56 UTC
HRM calories calculation
As far is I know the amount of calories consumed is calculated by Run.GPS with a formula like: Distance * Sportstype multiplier * weight factor (probably non linear).
I'm more curious about how this amount is calculated for those who use a HRM.
When I analyse my own recordings the differences between trainings with / without HRM seem to be fairly small:
Cycling without HRM: 26 kCal/km
Cycling with HRM: 30 kCal/km ( = +15% )
Racebiking without HRM: 28 kCal/km
Racebiking with HRM: 30 kCal/km ( = +7% )
(bodyweight always between 70 and 80 kgs)
But there seem to be people who burn over 50 kCal/km while cycling (using a HRM) which seems to be quite a lot.
In such a case I would have burned almost a million calories the past 12 months, which is very unlikely.
Anybody got an idea what can cause these big differences?
Grtz,
LeMarquis
Psybadeck 28.05.2009 20:49:22 UTC
that's ok
from my personal knowledge in physics, that is not the worst way to calculate it.
Five things should be considered:
1) Distance
2) Height
3) Efficiency (e.g. bearings of the bike, stop-start losses ...)
4) Wind
5) Weight
As I understand, 1,2 and 5 are considered. This should be pretty good...
Can anybody of the programmers add some information?
mae 27.05.2009 22:34:34 UTC
poor calories calculation
I just fiqured out that calories are calculated simply x*distance. It does not matter how fast you go or how you clime, only distance and constant by sport is multiplied. Maybe this is fixed in future versions?
