I would also like to have this feature!!
I also tested the program "Turbo-GPS" in this program you can create a route simply by drawing it with your stylus.
Maybe I will use it again because of this function - if I've managed to get maps into it :-(
I'am using Run.GPs for aeronautical navigation. In most cases a route consists of several waypoints (e.g. to avoid restricted areas). If I want to plan a route by using Run.GPS it is only possible to create a route from A->B directly and it is impossible to set some waypoints between. The route creation including waypoints would be be very nice feature in Run.GPS
