GPS-Sport ForenRun.GPS Wishlist / IdeasTraining Log enhancement
recneps 31.01.2008 20:39:22 UTC
Similar problem
I was also wondering how to change the sport afterward, and followed your directions below...unfortunately, for my mislabeled mountainbiking session, loading the training then changing the sport to cycling resulted in the distance, training time and active time numbers being doubled!
Did I do something wrong? Could I have loaded the session twice?
jlast 18.01.2008 13:53:25 UTC
Thanks Robert !
Regards,
John
robert 16.01.2008 16:54:51 UTC
Hi jlast
you can change the sport afterwards by loading the recorded training from the 'Training Log', then changing the sport as usual and uploading to the portal again. When using the latest release 2.1.0 build 772, the training will also get synced if you want to use that functions.
Regards
eSymetric
jlast 11.01.2008 14:23:25 UTC
Currently it is not possible to change the Sport type afterwards of a recorded training.
If you have selected a wrong sport type at the start of a training session, it is not possible to change it afterwards.
The training type can be modified on the portal after upload, but i would like to make this change on the phone itself.
