GPS-Sport ForenRun.GPS Wishlist / IdeasCompetition / Import route from GPX file
Bosti 06.02.2008 18:40:12 UTC
Thanks for implementation :-)
Bosti 23.01.2008 23:08:51 UTC
It would be great to do the same as with route...
Add Compete Against to Download Cart. In the Ranking table.
Regards, Bosti
robert 23.01.2008 13:06:49 UTC
You can do that:
1) import the route from GPX
2) edit the route with Route Planner if you want (not required)
3) follow the route with Run.GPS
4) upload the recorded training
=> the training will get assigned to the route if it matches exactly enough
One restriction: you cannot use GPX files imported into the GPS-Sport.net portal as Virtual Training Partner because the timestamps are not imported. Therefore, Run.GPS cannot compare the current times to the route's times.
Best regards
eSymetric
cfernandes 23.01.2008 12:39:19 UTC
I think was nice to have route competition working with import route from GPX file or allowed to import trainings from GPX file and have competition working.
Thanks.
