GPS-Sport ForenRun.GPS SoftwareOziExplorer Maps inside Run.GPS
robert 12.08.2008 10:37:23 UTC
This might mean that the maps are too big to be held in main memory. Try to store the map in slices (option in Map Calibrator).
thehijacker 11.08.2008 07:30:34 UTC geändert am 11.08.2008 09:24:42 UTC
I already have a buch of maps for the OziExplorer software wich are perfectly calibrated. They are currently in PNG/TIFF/JPG + MAP format.
Is it possible to use them in Run.GPS or do I have to create a calibration procedure once again? Is there a procedure to convert the MAP file with coordinates to something Run.GPS will recognise?
Thank you for the answer.
Edit: OK. Found some tools to create GMI file from Ozi Map file. Works perfectly in Map Calibrator. But as soon as I put it on my PDA (HTC Kaiser) I am unable to use any map. When I try and select it I get an OutOfMemoryException error. What could I be doing wrong?
