GPS-Sport ForenRun.GPS Wishlist / IdeasEvent notifications
robert 11.02.2009 10:05:30 UTC
Thanks for the info about vibrating.
I think it would make sense to vibrate when
- training is started/stopped
- new lap starts
- interval is switched
- HR/speed limits are left
- GPS signal is very weak (too weak to use)
- 200 m ahead of a turn
But it must be configurable (enable / disable).
We'll think about it for 2.3.1
ernst.maurer 09.02.2009 12:28:12 UTC
you are right, this interface is specific for the device,
but actualy, most of devices have very similar set of abilities there.
Typically, we are using
NLedGetDeviceInfo/NLedSetDevice functions to request/set vibration mode,
WM treats vibro device as one of LEDs.
By the way, you can work directly with GWES.
this solution works for most of WM Pro/WM Std devices, unfortunatelly WM Classic hasn't this hardware device.
Ernst.
P.S. Current voice output is a good thing, but not for all situations - this feature is not localized, voice requires long time when I need quick take off the lap/interval.
Simple beep or/and switch on the backlight for 2-3 seconds would be useful.
thank you in any case. great software!
robert 09.02.2009 11:18:51 UTC
I'm afraid there is no common interface to access the vibro ... so you'd have to do it individually for each device - which is impractical.
ernst.maurer 05.02.2009 23:29:03 UTC geändert am 05.02.2009 23:29:59 UTC
Hello,
I see there are a number of voice notifications about most of events during the training session,
but often I don't hear them on loud street.
Is there ability to add vibro for for interval training: if I left the HR/Speed predefined range, and for interval markers?
Rgds,
Ernst
