GPS-Sport ForenRun.GPS Wishlist / Ideasbluetooth autoconnect
ernst.maurer 13.04.2009 13:29:59 UTC
Thanks for the idea,
Actually, I use the same method but wrote usual C application for quick work.
But would be better if developers implement this within RunGPS application....
mattone67 09.04.2009 19:00:16 UTC
'Meanwhile' solution
Hi Ernst,
I got a similar problem on my HTC touch dual. To fix it, I installed on my touchphone the Mortscipt v4.11 interpreter with which I've tailored a script (.mscr extentioned) like the following to automatize some recurring operation: turn on bluetooth, 90 degree rotation of the screen, set loudest volume, set brightest backlight, retreiving all orignal setting when finishing.
When I didn't find any reference in the User guide of Mortscript about retreiving current brightness values for the screen, I use same trick accessing directly to the used registry from my OS (WM 6.0). The reason for which I did it was to restore the original display brightness levels when exiting form the script.
Another Mortscript leak of usage is bluetooth switching. Fortunately I find an utility from Teksoft called A2DPToggle giving the capability to switch bluetooth by using different launch parameter values when calling it.
Here is my script.
G.
# RUN.GPS su HTC Dual Touch
# - Accendi Bluetooth.
# - Girare lo schermo di 90° in senso orario.
# - Aumentare al max la luminosità dello schermo.
# - Aumentare al max il volume (togliendo ev. silenzioso).
# - Lancio Run.GPS UV.
# - <ripetere l'elenco in senso inverso>.
# Nota: provare ad automatizzare anche per run.gps.
# Lancia il profilo stereo e accende il bluetooth
Run("\Scheda di memoria\Programmi\Teksoft\A2DPToggle\A2DP.exe","-bluetooth:on")
# Ruota lo schermo di 90° in senso orario
oldScreenPortrait = Screen("portrait")
If(oldScreenPortrait = True)
# Message("Ruoto lo schermo di 90° in senso orario")
Rotate(270)
EndIf
# Accende lo schermo e lo mette alla max luminosità
oldIntensity = RegRead("HKCU", "ControlPanel\BackLight", "Brightness")
oldIntensityAC = RegRead("HKCU
ernst.maurer 08.03.2009 00:22:22 UTC
RunGPS connects to bt equipment automatically. that's great. but I need to perform switch on\off bt each time when I start\stop application.
Could you add feature to enable bt automatically at start time, if there is bt equipment in current settings?
Rgds,
Ernst
